Finally did a piston replacement on my B7100. Its sort of going again but I've noticed that fuel is leaking from the fuel pump connections to the injectors. It wasn't happening before the rebuild. Upon inspection it looks as if the O-rings on the connectors are broken or very hard and need replacing. Does anyone know what size they are in terms of inside diameter and thickness?
