B7100 Clutch flipped? Unhooked?
Jangulaallen
B7100
Jan 9, 2025
Hi, wondering how screwed I am.
I have a B7100 with a snowblower on it.
When I start it, I just stand to the side and hold clutch down with my foot to start it. ( yes, probably not the smartest thing to do)
I slipped and put too much weight on clutch pedal and it went way down. Bent the limit arm / nut and clutch was straight down, was pointing at ground.
Now clutch will not dis-engage. I can not put it in gear, just grinds.
Hoping there is an easy fix, not that I broke throw out bearing or the fork.
Where do I start looking?
Best regards,
8,304
Well, highly unlikely you broke the bearing.
But very likely you broke the fork or the pressure plate fingers.
No matter what you're going top need to split it to fix it.
If you can't do it or find anyone local to do it, throw it on a trailer and bring it on over and I'll do it.
I love working on B7100's!
Jangulaallen
B7100
Jan 9, 2025
That is what I was figuring I would have to do. Crap.
I was hoping for an easy fix, like a shear pin in shaft.
Will need to find transmission manual.
Be a "in the spring" fix
Might be time to break down and buy a newer unit or a small skid steer.
I've been looking at those little Chinese stand on skidsteer with snowblower attachment.
