Hi
My B2920 has an intermittent hydraulic leak. Appears during snow plowing - seems to occur when the unit is warmed up from having operated for awhile, and appears to occur when backing after dumping load. Leaves a streak of fluid and then stops.seems to be coming from above the hydraulic fluid filter (not transmission filter) - which is on the right side of the tractor about in line with the front of rear tire.
Is there a pressure release in that area that could be burping out some fluid - it isn't clear where it is coming from?
Anyone experience this?
Thank you for the help.
Pete
Pete
