B2650 GLOW PLUG ISSUE
TCB8585
B2650
Jan 3, 2025
I have a B2650, back in July I noticed the glow plugs light isn’t coming on when suppose to on dash, and the glow plugs are not working, hard starts. I have power to relay, however only coming into relay, can’t get power any other prong when turned over to glow spot. Anyone else have this problem and there solution? Note: I have already replaced relay and glow plug 40 fuse.
8,051
You should have 2 Power feeds going to the Glow plug relay:
One constant via the 50 amp Fuse (yellow) on the red/white wire.
One switched via the 5 amp fuse (green) and white wire.
