B219 on B7100 Removal Tips/Tricks?
2,309
Any advice out there?
Stands that need to be made?
I will be starting the removal of mine soon....
Lencho
B7100hst
Jan 21, 2017
411
87
NM
Hi Lil Foot, I first Thought you were removing your backhoe but the B219 is your FEL. Is it basically self contained? Pump off the front of the engine and hydraulic fluid in the arm? If so it will just be a lot of bolts to remove and an overhead hoist or gantry to relieve the weight.
I am curious why you are removing it.
2,309
This thread should clarify why I need to remove it.
Pulled the backhoe off last trip to the high country, FEL is next.
I've had the hoe on/off a couple times, but never the loader.
Not looking forward to this teardown/repair.
I just hope the cases aren't cracked.
