Hello -
I am considering a B21 TLB, several for sale nearby. I plan on using:
tiller
PH auger
bushhog
box scraper w/rippers
disc
spring tooth rake
pallet forks
I've used the B21 before, but only the loader & hoe, no implements. Questions:
Does this machine have enough power for a 52-60" tiller? The track width indicated is 53", so I'd want a tiller wide enough to cover the tire tracks...
What would be a suitable size bushhog for this?
Don't want clamp on forks - is there a source for pallet fork which would replace the bucket?
Would this be a suitable machine for small acreage use? I understand there have been issues with cracked differential cases prior to s/n 63853, obviously a unit with later s/n would be preferred...
Thanks!
elixir
tiller
PH auger
bushhog
disc
spring tooth rake
pallet forks
Thanks!
elixir
