S Schmotown New member Equipment B1700 HST D Oct 17, 2024 2 0 1 MI Today at 9:02 AM #1 I have an "old type" B7100 HST D with a leaking oil pan. Can the front frame/axle assembly be disconnected and rolled out of the way to drop the oil pan like we could do on the gear driven version? Thanks, Larry.
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 29,843 6,046 113 Sandpoint, ID 58 minutes ago #2 What tractor do you have because your profile says B1700, your other post is B1700 and you are now asking about a B7100????? Yes you can pull the frame bolts and move the frame and axle out of the way.
