Attaching and wiring LED Bar to ROPS (and work light)
Mike OMelia
L3560, RTV 1100, ZD1211-60, Landpride 72" bucket, grapple, rotary cutter, grade
Jul 5, 2024
Brownsboro, AL
I have a new '24 L3560. Ordered a 32" lightbar for the ROPS. Includes wiring harness etc. And a rear facing worklight.
Problem is, no obvious place to attach (predrilled holes). No power point access in the rear. Instructions want direct access to battery (in the front) which does not leave enough wire to reach the rear. Anybody done this before?
MOOTS
MX6000
Jun 27, 2019
1,866
2,116
Canton, Georgia
There “should” be a fused work light pigtail on one of the rear fenders.
MOOTS
MX6000
Jun 27, 2019
1,866
2,116
Canton, Georgia
Gray one has the other side stuck in it. That may be it. Get out the volt meter and start poking. Fuse should be labeled in box as work light.
Mike OMelia
Jul 5, 2024
Brownsboro, AL
Ok, I'll probe all four tomorrow. Regardless, I'll need kubota branded connectors to make it all work. I think. Will put this off till next week. Good news is I found four potential fused wires that look like they are meant for auxiliary items!
Mike OMelia
Jul 5, 2024
Brownsboro, AL
OK, just saw what you were saying, found the part, how do I use it? has these rubber things in way. I moved one.
The Evil Twin
L2501, LA526,
Jul 19, 2022
2,733
2,707
Hard to tell from the photo what connector that is. Personally, I cut off the factory connector and added my own plugs with a kit from these guys. Some kits come with all the tools you need.
MOOTS
MX6000
Jun 27, 2019
1,866
2,116
Canton, Georgia
I don’t think that can be used, more of a dummy plug to keep stuff out. I could be wrong though. Like evil said, chop that end off, if it is the work light circuit and install a connector of your choice.
4,733
