antifreeze
Jim L.
831
107
It should be ethylene glycol. You can't go by the color. I'm not aware of any magic ingredients, so auto parts, tractor supply, dealer should work.
The Evil Twin
L2501, LA526,
Jul 19, 2022
2,489
2,449
is kubota antifreeze differnt from what you get from auto parts
Depends on which one at the parts store.
IIRC, the K recommends a ethylene glycol base phosphated coolant that is free of silicate, nitrites and borate.
Zerex Asian Green ticks those boxes. Rotella ELC does not.
4,343
@The Evil Twin knows much better than I do, but I think I did Zerex a year or two ago.
Checked all the boxes as he said.
The Evil Twin
L2501, LA526,
Jul 19, 2022
2,489
2,449
I believe , but haven't confirmed, Motorcraft VC13G can also be used. I know it is a PHOT coolant. Not sure on the nitrites and borate. The addition of phosphate implies an absence of silicate. I had both VC13G and the Zerex Asian on the shelf. I just already knew Zerex met the spec.
lmichael
Kubota G2160
Apr 23, 2021
575
221
Rockford IL area
Last year I asked the Kubota dealer here, for coolant so I could change it. They were out and I asked what to use. He happened to see my Toyota and said the coolant for it is perfect. I said I have the Toyota SLL Pink pre-mix and he told me that or the Honda (blue) equivalent is perfect. That is what is in it now the past year and no issues at all
3,700
Kubota branded antifreeze is a silicate and nitrate free PHOAT long life ethylene glycol coolant which is the formulation used in many modern Asian vehicles.
My L3901 owners manual is not that specific and simply says "long life ethylene glycol" coolant which encompasses just about everything sold today. What it excludes is old fashion "green" Inorganic Acid Technology (IAT) that needs to be changed every 2 years.
FTG-05
Jul 21, 2013
263
103
TN
I just use the reg green BUT I have heard there are certain ones better for diesel motors.
Any antifreeze meeting CAT-EC-1 requirements. I like Fleetrite, simplly because I can get it cheap by the case from the local International dealer; but any EC-1 AF will work.
