Alternator/water pump belt replacement
farmboy24
G5200HST
Jan 13, 2024
E Texas
I'm new to this forum, so this question may have been discussed before, but I've not seen it. I own a G5200 that dates back to the mid 80's, and the alternator belt has finally worn to the point that I have no more adjustment left on the adjustment bracket. Since the belt goes around the water pump, alternator and propeller shaft, I need to know just how much of the tractor do I have to disassemble to get the old belt off and the new one on? Any help will be appreciated.
8,173
3 bolts on the coupling on the crank.
And loosen dynamo.
farmboy24
G5200HST
Jan 13, 2024
E Texas
Thanks, Wolfman! I was hoping that it would be simple. Guessing that I undo the bolts and slide the coupling back far enough to slip the belt through.
