7100 no electrics at key switch
1,762
Find main fuse or fusible link and see if it needs to be replaced. It is probably near the starter area of the tractor but I am guessing at the location.
1,762
Check the cables and the ground point for corrosion also.
8,311
This has such a simple electrical system, one safety on the clutch pedal.
So you should be able to narrow it down fairly quickly.
That model has a fusible link just above the starter and that's it for the main.
