48 inch landpride box blade
Bearcatrp
Mar 28, 2023
763
425
Minnesota
Found an almost brand new landpride 48 inch box blade. $695. Did some searching and the closest I could find was $900 and not in the best shape. Good deal? Will be my 1st box blade. Thanks
7,856
I paid $628 in June of 2016 for a new Land Pride BB1248 box blade, so yeah, $695 for an almost new equivalent is basically paying 2016 new prices in 2025. 😂
Using a simple inflation calculator, $628 in 2016 is $835 in 2025, and the current price of around $950 is consistent with a Kubota/Land Pride price increase of around 10% to 15% over that time period, most of which occurred in 2020/2021.
Bearcatrp
Mar 28, 2023
763
425
Minnesota
Just brought it home. Couldn’t pass it up. Thanks for the reply
Bearcatrp
Mar 28, 2023
763
425
Minnesota
It must be an older model as it won’t mount on my quick attach. Off by a half inch. Will have to remove my quick attach to mount it on the 3 point. For the cost, I’ll deal with it.
armylifer
Mar 26, 2013
2,088
833
Thurston County, WA
Which model of the Landpride Box Blade did you get? I have the Landpride BB1548 and it fits on my Harbor Freight Quick Hitch. I had to move the top hook of the Quick Hitch to get it to fit but it works fine after moving the top hook.
BTW, I paid $700 for my BB1548 new in 2015, so I would say you got a good deal on yours.
armylifer
Mar 26, 2013
2,088
833
Thurston County, WA
Landpride BB0548
Here is a link to a pdf of the operator manual for your BB0515.
Check out page 10 of the manual it tells how to configure it for CAT 0, CAT 1 Limited, and CAT 1, 3 point hitches. Check out this excerpt from the manual. This note suggests that the box blade can be hooked up to a quick hitch. You will probably have to adjust the box blade pins for a CAT 1 3 point for it to work with a quick hitch.
NOTE: Land Pride’s Quick Hitch can be attached to
the tractor to provide quick and easy 3-point hook-
up and detachment. See your nearest Land Pride
dealer to purchase a Quick-Hitch
Bearcatrp
Mar 28, 2023
763
425
Minnesota
Am off about a half inch on the hooks on my land pride quick attach. Those hooks don't move. I will take some pics next time I go hook up. Only way is remove the quick attach since the lower 3 point arms move.
