The tractor is new and under warranty but I wondered if anyone else has trouble with the switches sticking. Dealer installed on O hour machine. At first I thought there may be air in the hydraulic system and I went through steps to eliminate that. Then I noticed that a microswitch would randomly stick in the momentary activated position, sometimes popping back out on its own and other times needing to be tapped a couple times. Not really cold out (30"s) so don't think that's causing it. Anyone know if the switches can be changed out by themselves or the wiring harness to the switch is part of that assembly?
