Hello all,
As I updated in "buying advice" I now own a used 2015 RTVX-1100 side by side.
After getting it home I changed the motor oil and filter, fuel filter, and both filters in the rear under the muffler. Vacuumed and blew out the 2 engine air filters, and vacuumed the cabin air filter in passenger side dash.
The next day I started it and used it to do some yard work. I started it and let it run for approximately 2 hours continuous and then turned it off for lunch. Came back and when I tried to start it there was nothing.
I had it in neutral, parking brake on and foot on the brake, nothing. I tried all configurations of this, parking brake on, off, foot on brake and not on brake and still nothing. I tried rocking forward and back just in case there was pressure on the gears and nothing.
I had my wife sit in it and steer while I used my tractor to pull it all the way bak to the garage. I tried jumping it with my truck, nothing. I removed the battery put a volt meter on it and it registered 12.85 volts.
I then took it to the auto parts store to be tested and it showed good battery.
Reinstalled the battery and it started. It has done this now three times, and it is disappointing and frustrating.
Is there a safety switch or something that I can check or am overlooking? Is there some sort of adjustment I need to make?
The only manuals that I was given with it were for the Boss snow plow. I downloaded the operators manual for RTVX-1100 and the RTVX series, and the 3 part WSM.
Thanks in advance.
Thanks in advance.
