Repowered my jeep with kubota turbodiesel
KubotaMightyMite
kubota powered micro jeep
Sep 3, 2012
sultan, wa, usa
After owning a kubota powered excavator for 6 yrs with zero issues, I decided to use a kubota engine in my newest project...it is a very rare aluminum micro jeep with independent suspension...
I was unhappy with the original air cooled V4 gas engine, so I transplanted a V1505-T engine into the lightweight Mighty Mite...had to have an adapter plate made to fit the 4 speed tranny, and a combination of off-the-shelf clutch parts.
After a few months of researching, and collecting parts, and a weeks worth of labor, I have it up running and drivable.
Wow is it fun! Torquey, and quick...and an added bonus is that the little 4x4 now gets in excess of 40mpg!!!
Knowing I would be pushing the little 4 cyl hard, and that I would be wringing more power than stock out of it, I decided to go through the whole engine I bought.
I installed new pistons, rings and berrings. Also, more importantly, I added piston oil coolers to the undersides of them...I did this by having two tiny holes drilled in the con rods and also had the rod berrings machined with a U-groove in the center with holes that match the new ones in the rods...this way pistons get a constant spray from two oil squirters.
I removed fuel rack stop screw, throttle stop screw, and turned in torque screw one turn. Lastly, I installed an extra spring on the wategate for more boost...
The power is awesome! Boost pressure jumped from 7psi stock to around 14psi...
3,588
Pics! We need pics! Sounds cool!
OkieDavid
L 3010
Aug 29, 2012
46
Valliant, OK
I second the "pics" comment. I am a firm believer in the internet forum mantra of "if you don't include pics, it didn't happen"... Sounds like a really cool project and would LOVE to see some in progress shots.
Bluegill
Jan 11, 2012
1,559
Success Missouri
I have a 1994 Toyota 4wd truck with 270,000 miles. Runs great but it might eventually need a motor. I would like to put a Kubota diesel in it.
So, pics of what you did will help. :cool:
3,588
You've got a ways to go yet...... my '78 Toyota pickup had 431,634 on it when I traded it in on a '95 Tacoma.
Stumpy
L175
Dec 1, 2011
848
NE Ohio
Better late than never!
That is very cool! Looks a little tight in there you using an electric fan?
5,704
What is it??? That aint like no Jeep I ever saw, or is it some kind of ricer????
I think the install is a pretty slick set up !
