CaJohn New member Equipment BX2230 Aug 4, 2010 1 0 0 Florence, Texas Jul 4, 2012 #1 Where can I find the torque specifications for a D902 engine?
B Breeze New member Equipment L3700, Box Grader, 60" Bush Hog, Rear Grader Blade, York Rake, Boom Pole. Dec 24, 2010 149 0 0 Virgin Islands Jul 7, 2012 #2 Posts die due to insufficient information. D902? Tactor/generator/mower? Post more information.....
motorhead Active member Equipment 2009 B3200, 2007 Dodge/Cummins powered Ram 2500 395hp May 17, 2012 441 42 28 Atascadero Jul 7, 2012 #3 Check this:http://www.tractorsmart.com/KubotaEngineSpecs/Kubota Engine Specifications B1700.html
76_Bronco Member Equipment B7200 4WD w/FEL, 4' disc, 4' Brush Hog, 14" Plow, 4' Blade, JD 246 2 row Planter Mar 28, 2012 182 1 18 Rainsville, Al Jul 8, 2012 #4 CaJohn said: Where can I find the torque specifications for a D902 engine? Click to expand... If your engine is a D902-E2B then download this service manual > http://www.kubotabooks.com/AutoIndex/index.php?dir=Engines/&file=SM-E2B series.pdf
