20.5x8-10 correct replacement available
tiredguy
B3030 HSTC,B2781 51" front mounted snowblower,60" MMM
Jan 21, 2010
301
northern lower Michigan
For all those who need the correct replacement tire with the exact rolling circumference for their factory 20.5x8-10 Bridgestone Pillow Dia turf tires
and the 21x800-10 Firestone Turf & Field tires which were both used as original equipment tires on Kubota's and other tractors I have good news:
Firestone Ag is back building the 21x800-10 Turf & Field which has the correct rolling circumference of both of these sizes of 61 inches.
The Firestone article (part) number is 382653 so call your local dealer or go to:www.firestoneag.com and use the "dealer locator" feature to find the nearest dealer to you by zip code.
I've had them in stock for about 2 weeks and apologise for not posting this as soon as I got the news because it is such a good thing to know. I've hammered Firestone with verbal calls and emails etc since the day they stopped making them and really glad that they brought them back because the only solution I had come up with to date that matched rolling circumference was the Carlisle USA trailer tire in size 20.5x8.5-10 using the 6 ply rated ( load range C ) and running at 35 psi inflation. Ok for mowing the lawn but not much good when trying to move snow with a blade or snowblower.
Al
tiredguy
Jan 21, 2010
301
I believe the correct Firestone part number is: 381-653
http://www.firestoneag.com/webres/File/Tire-Info/TireCatalog.pdf
Very helpful post! I'm ordering a pair for my Yanmar 147D.
I stand corrected for sure, must have ten thumbed the keypad or simple screwed up dyslexia moment as the numbers do get jumbled when I look at them hundreds of times per day LOL!
All good though and thanks for posting the Firestone Ag Tire Catalog link too.
I'm not tired for no good reason.
;-o)
