Kubota B1-15 moves dirt with selfmade front hydraulic
cabu
Kuno B1-15 (B1502DT)
May 24, 2009
736
Germany, Oyten
Video: Kubota B1-15 moves dirt with selfmade front hydraulic
Hello my friends,
here is a new video of Kuno.
I improved the bucket and get it working with my front hydraulic lifter. Both is homemade.
I hope to give an idea what the tractor can handel.
der carl
Stumpy
L175
Dec 1, 2011
848
NE Ohio
Looks good! Lift height isn't bad either for what's basically just a plow lift. I like your solution for the bucket tilt. Nice work!
cabu
May 24, 2009
736
Germany, Oyten
... Lift height isn't bad either for what's basically just a plow lift...
Thanx.
Actually I built it not for a snow plow. The idea was to move dirt around. But no need to lift it high. A FEL would cost to much and my homemade front 3ph suits my needs very well. :cool:
Kytim
Aug 14, 2009
848
Western Ky
Cabu, I really like the work you've done. I think i've even told you that before. If you lived next to me, one of two things would happen. I would swipe your front 3pt from your tractor to put on mine or, continue to beg you to build me one until you did! Just kidding, but I do like to quality of your work and wish the US would embrace the idea of forward 3pt more.
keep it coming!
5,691
Well carl it sure do beat the hell out of a shovle and wheelbarrow,,lol,,, ya done good!!! Now what kinds of trees you got there in the orchard???
cabu
May 24, 2009
736
Germany, Oyten
@ Kytim: Thank You !!
... Now what kinds of trees you got there in the orchard???
Most of the trees are grown wild. What you see is only 5 years old!! Most are birch and willow. Additional to that I bought some Sequoia, Redwood (because I have seen them Califonia), a sycamore tree, a ginko, some oaks, a swamp-oak some others I don't know.
The idea is to extend my little forest of spruces, but I think it will take a while, and I will have fertilized it with my body... ;)
der carl
cabu
May 24, 2009
736
Germany, Oyten
The hills of dirt are now pushed around and filled the holes and rised the ground a little bit.
The rest of the dirt at the left side will be used to built a little hill for the kid's.
It took 7 hours and 2 gal (~8 L) of diesel to get 50 cbm (1775 cu.ft) moved.
