I've looked and looked for a snow blade (g2001) for almost six months to plow my two driveways with. They have been discontinued for years. The only ones I've found were at dealers with tractors And no one would separate them. The g1700/1800/1900/2000 all used the sane plow and was a mid lift design that used The existing belly mower mounts and lift setup.
So I bought a B2750 front blade setup off of craigslist for 150 bucks. This was designed for a B5100
I didn't want to chop up the existing mounting brackets in case I get a bigger tractor I can reuse it ( with minor work)
I made a Reese style front hitch for the tractor. I then took lots of measurements and made a slide in receiver style front connection. I simply welded some 4" channel in between the factory mounting brackets and then welded that to the 2" box tube.
I wire wheeled and sandblasted what I could. I then POR 15'd the entire setup for long life and good looks. I misted sons kubota orange on while it was still tacky
