davemskinner
Sold ZD28F, Bought04 Grnd L4330 /frnt mnt snwblwer L2185, hted/AC cab, 2nd ZD28F
Can anyone tell me if the gearbox for a ZD28 mower deck is the same as for a ZD28F? I have the gearbox apart that came on the above deck. It appears to be different from the parts diagram.
I have spent $600 on parts and they don't fit. It appears the box is too small for the pinion shaft and gears. My only thought is that the gearbox was swapped onto this deck from another model. In the second picture, the two boltheads on the front facing side are not in the parts diagram. The fourht picture shows how the baering will not seat deep enough to put the sanp ring in. The last picture shows the pinion gear on the pinion shaft. There is a shoulder separating the shaft into to sections and the gear only slides on the splines as far as they are ground down to allow. The gear does not seat all the way up to the shoulder.
