Does anyone have a working knowledge of the older B670 (KUW200) backhoes that were made for the older B6100 Kubota tractors. I am trying to rebuild one and have found that the area that the bottom pin of the swing weldment goes into is worn out and out of round. The raised round piece of metal that is welded at this location is completely shot. The repair manual calls for a "ball joint" at this location but does not go into specifics about how it goes on. If one is supposed to be there, its not on mine. I am going to have to cut off the raised ring where the pin goes in and find a piece of pipe that is similiar in OD and ID and weld that on. The part number for the ball joint is 70020-00784 but I have not confirmed the part is still available. I have attached the address of a site that has the manual for this backhoe. If anyone has worked on this type of backhoe or even better, has this type of backhoe and can get me pics that would be great. Any suggestions on how to go about repairing this would be greatly appreciated. I have just finished rebuilding both swing cylinders and cannot put them back until I resolve this issue. Thanks, Glenn
www.kubotabooks.com/AutoIndex/index.php?dir=Backhoes/&file...
