Wow I know I must have got some of this right
-The reason for rebuilding the head was this oil in the radiatior problem. I noticed it blowing oil STRONGLY out the overflow tube. Thats what got all this started. Talked to the kubota shop and they said most likely blown head gasket. So I took the head off and had it gone through anyway ( they said it was a mess inside) It did the same thing afterwards with the same intensity.. pressure in radiator and oil out the overflow.
-I did torque the bolts in sequence. New gaskets used. Didnt see any white sealer on the bolts that I recall. I could be wrong though.
I did put the bolts back in the right spot. I photograph everything and every step as I dont trust myself. No I didnt save the photos unfortunately.
-The smoke is black/grey and diesel smelling. Takes about 2 minutes after prewarming to get it going and it clears in about 15 seconds. As I said this was a definite change from its previously easy starting.
Could the valve clearance have changed after settling in?
I could have set that wrong too...but like I said it runs like a champ once its started.
-I didnt have any coolant, water etc in the block after head was removed as the lower rad tube was off. Im in california too with the mild winter temps.
- The water neck was not cracked but badly corroded.
- The radiator always leaked. The shop had to recore it.
I cant find an adapter to fit the glow plug hole in my stuff unfortunately. I have 10mm but the thread pitch kubota uses is different. I also have a leakdown tester but again no adapter that will match the thread pitch.
I hope we can get this problem isolated its really bugging me. I havent taken the tractor apart yet in case there are further tests we can do Rechecked the radiatior pressure at 16lbs..holds solid for 3 min or so. Starting the tractor did not vary the pressure at all and I lowered it to 6 lbs.
Damon
