after market fuel/water separator filter
I don't like the fuel filter on my L2501 so I have been looking for a replacement and I think I found one that will be a lot better then the factory one and I can add a fuel shut off that they should have put on from the factory.
Here is what I found........and it's on the way.
http://www.ebay.com/itm/RACOR-120AP-...hZPr3S&vxp=mtr
OVERVIEW
The Racor 120 Series fuel filter and water separators offer Racor proven protection in a small, compact package. The 120 Series offers reliable protection for smaller diesel engines used in generator sets and small construction equipment. Their compact size fits tight mounting locations and cramped engine compartments. Multiple ports offer installation flexibility.
Among the 120 series of filters, these A models offer a lower 15 gph flow rates than the 120B models, and are smaller in size.
The 120 Series assemblies feature spin-on, high-capacity, Aquabloc® II replaceable filter elements which stop 99% of water, remove solid contamination, and are available in 2, 10, and 30 micron ratings.
Filtration needs should be based on application, fuel quality, operating climates, and maintenance schedules.
• For vacuum side of fuel system (tank side of fuel pump)
• 15 GPH maximum flow rate
• Reuseable spin-on contamination collection bowl
• Clear bowl allows water and contamination levels to be seen at a glance
• Clear bowl will not discolor from alcohol, additives, or UV light
• Mounting head has four 1/4"-18 NPTF ports with standard vent plug
• Height: 6.5"
• Bowl has a positive seal drain for easy servicing
• Bowl has a port for an optional water detection kit
OVERVIEW
• Height: 6.5"
