L1500 Transmission oil question
Adam12
L1500
Jan 5, 2017
Melbourne, VIC, Australia
Hi guys, first post on the forum.
I recently bought a L1500. Thought i would give it a service before i put it to use, glad i did when i looked at the transmission oil strainer!
So i know i need to use a 80w90 oil for the trans/hyd. I purchased 20ltrs today but now realised i need around 23ltrs. I do have 5ltrs of 80w90 bought some time ago. The oil i have is the same brand and is still a mineral oil, do you think i would be ok mixing a few ltrs of the same brand 80w90 with it as i already have 5ltrs
Cheers guys
Sent from my SM-G930F using Tapatalk
6,545
Yea you can mix those 2 in that tractor with no issue. ;)
jkk04
kubota l1500, JD 410 backhoe,MF 30 tractor, IH TD14 142, BCS 715 tiller
Jan 9, 2017
79
PLYMOUTH CA
Hi, Adam 12.
glad to see your thread
I bought same tractor 10days ago.
It is runs good except reverse function and steering.
so having so much questions on this little tractor same as you.
I am replacing reverse gear and complete steering assembly in a month.
Hope we can share some information each other.
cheer
6,545
There is either 2 or three, I'm not really sure.
Look in the center of the transmission, if there is a third that is where it will be.
The one that is on the side of the transmission by the clutch pedal is not a drain plug but a level fill plug. ;)
1,434
There are at least two on the bottom of the transmission and one on each axle (may have 2 each axle).
The axle are lower so will drain the last few quarts of fluid so do both sides.
There is a plug on the side of the transmission near the clutch pedal that is the correct level to fill to. ( as stated above)
