L185 drawbar
1,372
Does anyone have pictures of L185 drawbars?
The one on my L185 seems to be very different than what is shown in the parts listing. Mine is bolted to the bottom of the rear end and has a pin going through a long bar. The long bar extends out the back through another bracket with pin holes. I believe it is called a swinging draw bar. What is shown in the parts listing is a bracket that bolts to the tractor and can have a trailer ball installed or act as a clevis point.
I would like to see what others have to see if mine is stock or added from some other tractor.
5,445
Might go to Ebay and type in "Kubota drawbar". You'll find many lengths and widths, but you'll get an idea.
If your only challenge is your actual drawbar is different then what is in the parts book, you don't have a problem. It's a piece of iron used to attach "something" to your tractor, and you can pin it to one side if you choose to clear a PTO shaft, or any other reason. Put a ball, clevis, pin or bolt in a hole for any creative use you desire!
1,372
It is really the parts that hold the draw bar that appears different and there is no bar listed for a draw bar.
And it really is not a problem but curiosity driving this.
1,372
Thanks for the pictures. Mine is like the second picture (L245). I'll look on line to see what parts show up for the L245.
That helps a lot!
