So i am a total newbie to welding. Just got started teaching myself to weld with my new Lincoln 180 welder.
After burning through 2lb of 0.025" wire, i got down to welding my kit table i purchased from weld tables.
https://weldtables.com/products/cop...ng-table-top-kit-certiflat-by-tab-slot-u-weld
Here is the construction method
Its laser cut steel with torsion box design and tabs as you see inbpic above that fits in slots on table top.
Here it is all clamped up
Then welded
Here is the top welded slots and sanded
And here it is finished with legs and casters ....they supply a leg and caster kit as option, its really worth it.
Nice flat top, now for some fixture buts from stronghold.
This is a 2x4 size they have others.
I plan on making a plywood and mdf top to clip over table for other use when not welding. Will also look at making set of draws and put sheet steel across top of draws to protect them.
Great service good quality American ingenuity at its best. If u need a welding table check them out.
![](http://uploads.tapatalk-cdn.com/20161003/51590ecb61d6d600e39e06427f35bd28.jpg)
![](http://uploads.tapatalk-cdn.com/20161003/f82fa6f881760dc02bcf3ace84f693a5.jpg)
Then welded
![](http://uploads.tapatalk-cdn.com/20161003/8968f64a466dad956143409018425020.jpg)
![](http://uploads.tapatalk-cdn.com/20161003/bf5a394cbe792c791a0e7e58fea34ef9.jpg)
![](http://uploads.tapatalk-cdn.com/20161003/477721e8c92a7033af3e0969766a171f.jpg)
![](http://uploads.tapatalk-cdn.com/20161003/c0cca2091980ea66ff77db7a30ecf042.jpg)
![](http://uploads.tapatalk-cdn.com/20161003/fb29e5a307d7406ac9afbec8238e765f.jpg)
