Anyone transport their tractor in a dump trailer
mkcj
10
Seatac/Winthrop Wash
Not sure if this is the right place for this but wondering if anyone transports their tractor in a dump trailer, my plan is to haul my new B2650 in my 12' tandem 14K GVW dump trailer. Tractor is 13' with loader I'm told so 1 foot of bucket will need to be on the forward rail. Only implement I would need to haul between cabin and home would be the tiller and that can go in the back of my truck.
Sammy3700
L3800HST,524Loader,BH77,Landplane,Disk,Mowers and more
Feb 20, 2012
439
Red Springs, NC
I can haul my L3700SU with loader and box blade in my 14' with the loader bucket up on the goose neck. Do not know how to post pictures or I would show them.
ironpony
B7100
Mar 4, 2016
84
Lancaster Ohio
we have hauled and 837 Bobcat in our dump trailer. As long as you do not exceed the weight rating, also you need to make sure you can secure it in case of mishap that will be the hard part. oh and balance the load might be better backing in or pulling in
SilverRidgeEarthWorks
B2400 - Backhoe, mower, blower B3350 - Loader, blower
Nov 22, 2016
BC Canada
My 16' Suretrac has 5 tie down rings in it, can haul 10k lbs (3/4t Powerwagon can only pull 10,900 so maxload in the trailer is 6k). Haul my B3350 and B2400 all over with it. Even moved that JD dozer for a neighbour this spring ***128077;
Flienlow
Kubota BX25D, Kubota U25 mini EX, SVL75,Landpride Grapple,Landpride grading scra
Mar 9, 2015
352
snohomish
I haul my bx25 in a 5x10 10k dump trailer. Its a tight fit, and not optimal but I have done it several times now. No issues.
eipo
L4060
Dec 1, 2015
699
85
MI
Yes.... 14' trailer and I only have to set the bucket up on the tarp lip if I have something on the back.
Tooljunkie
May 13, 2014
4,150
I see tractors and skidsteers in dump trailers almost daily. Up here it doesent need to be secured if its got high sides. Bucket hanging over is a different story, would need securing.
cerlawson
rotiller, box scraper,etc.
Feb 24, 2011
1,067
PORTAGE, WI
You may need some traction assist for loading on. I secured cleats to my wood deck. Instead of loading going forward, I back on to get the center of gravity a little forward of the axle.
Tooljunkie
May 13, 2014
4,150
Cerlawson is right on the money, load heavy end first. And if you back it on,and exhaust points rearward,bag it. Wouldnt want to get water/snow blowing down the chimney.
Billdog350
Kubota L3710 HST,L2230A QT,forks,Takeuchi TB125, 60" Luck Now pto Snowblower
Jan 6, 2014
468
11
East Hampton, CT
I have moved my L3710 several times with my drop axle 6x12 10k dump trailer and 2500HD duramax. The trailer and tractor tow fine...no complaints.
With the tires loaded, my machine weighs in close to 6000lbs.
I did install tie downs in the bed so I can strap the machine down effectively.
If I have attachments, those do hang out the back of the trailer so I flag those.
I've also fit my Takeuchi TB125 in the trailer, also a 6000lb machine.
bearskinner
Sep 1, 2014
926
241
N. Idaho
That will be the plan, a 7x16 gooseneck dump..... the perfect set up
kenmac
B26 with hyd. thumb and 4 in 1 loader bucket and EA Grapple, but not the wicked
Dec 14, 2015
92
9
Pell City, Al.
Just to add my comment and confirm no problem hauling my B26 in my 14' Kaufman dump. It has 4 tie downs, but bucket must rest on front at level point near SSQA. Can put grapple in front under bucket.
