Oil pressure Gauge install B7100
3,091
D2Cat brought up a good suggestion, :)
(LONG POST)
itemize what is needed to install an OIL pressure gauge on a B7100 (or any other tractor) and STILL keep the idiot light!, having paid close attention to what NIW has said about "fittings" being BSPT ,(British) you would think that is strange for the Japanese to use British fittings - but it is quite common :
http://www.ralstoninst.com/news/story/the-difference-between-npt-bspp-and-bspt-seals/
however, damn near all other "fittings" are NPT ......
other than the pitch being slightly off and the tpi being off a smidgen - 27 tpi vs 28 tpi they will almost work together.
However - I really did not want to spend $20 for a freakin adapter! So.....I found this: (still 10 bucks!)
http://www.amazon.com/gp/product/B001DKM4PU?psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s01
T fitting :
http://www.amazon.com/gp/product/B006PKKXM4?psc=1&redirect=true&ref_=oh_aui_detailpage_o07_s00
And gauge:
http://www.amazon.com/gp/product/B00029K00Y?psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00
And a roll of teflon tape.....
So - I carefully got a small wrench in to get the sending unit wire off, hex with phillips inset, neither was a good tool to get it loose! Thank goodness the pliers were good enough to loosen it. Wire off and the unit came off easily.
Just for S&G's I tried to stick the T adapter (NPT) into the hole in the block, BSPT, I could not get it to start in the thread - even though it should "thread up" to a certain point.
Now the PITA part - my hands could not get the T and adapter and the rest in the tight area, so the engine skirt had to come off - well hell, aint no biggie, 6+ bolts and hold your tongue just right and it came off.
So thinking this thing through - I placed the old sending unit on the T fitting, the T fitting on the adapter (all with teflon) and THEN inserted into the engine block - the fat part of the T needed to spin around the battery hot wire that sits right down in that pathway, so a turn, a push on the wire, another turn, this way ALL THREE fittings spin and tighten with the same amount of force without placing too much on any one fitting. Finally got it snug and turned pointing up.
Now the gauge mounting was simple, however the plastic tubing they give you.......its like playing with a plastic slinky!!!! Aint no way you can fight that freakin coil of plastic without a kink or a kuss !
So - newly bought heat gun came into action, placed the gun on the table on low, pulled the tubing across the face of the gun, slowwwwllly straightened it out to the point where it would be usable.
Found out that I only needed about half of the tubing.....so a snip and I had plenty......now for the ferrules for the tube, well lets open the package of all the nuts and screws and what not......
one ferrule - where is number 2? ...... son of a $#%$#^ - O - I was pissed, a true 1 penny part was gonna keep me from finishing this $##$^$ thing! Looked everywhere - man talk about frustration.........
So picked up the gauge for some crazy reason, rattle in it, WTH? so what to do, shake the hell out of it......something falls on the bench, hits the floor....and pooooof - it too is gone.....never saw it hit the floor, so on hands and knees looking on a plywood floor trying to find this magic part.....nuttin, zip - so.......After about 10 minutes I backed up a few steps and whooop there was something up under the tractor tire - ferrule #2 !!!!! WHo in the sam hell sticks it IN the gauge light socket while the rest is in a plastic sealed bag?????
So - mount the gauge, place nut on one end of the tubing, and the ferrule and tighten the tube to the T fitting - no problem, route the tubing for a semi straight shot to the gauge, repeat the fitting...........
Crank the tractor - looking for leaks, none:), tube fills up to a point and then stops, mmmmmm........gauge reads about 60 psi - nice! Grab the wrench and back off the nut at the gauge just a smidge - fluid moves and then I clamp it down.......
SO - double check everything - place the shield back on, and two hours later - I am done!:D:)
Reality it would (should take about 30-45 minutes) if I had to do again!:eek::)
For 30 bucks round trip - money well spent, I'll report back ifn either gauge fails - heard reports of these type of gauges "failing" ......
SO - moving to the lighted end - since I had the temp gauge mounted, I simply tapped in to it's light hot/cold wires.......
so I fire it up again - and son of a beeeeauuucccch - the light on the new gauge works well BUT the other light is now cooked!!! So....back to amazon for bulbs......
another 10 bucks
http://www.amazon.com/gp/product/B00KLHBUJ2?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
but these should be bright! and not burn out!!!!
time will tell!;)
kubotasam
Apr 26, 2010
1,212
137
Alfred Maine
Re: Oil pressure install B7100
Nice clean install! Thanks for all the details and links.
7,718
So what does YOUR flat rate manual charge for this install? Can I get on your schedule?
It looks nice, besides it's a stress reliever knowing pressures/temp. at a glance.
3,091
thanks -
Amen on the last line !!!
Now - next order might be the ol' Canopy for the BX! :D:)
procraftmike
1977 B7100DT w/B219 FEL
Jan 27, 2016
277
10
Neenah, WI
T,
Great post and very informative. You sure saved me a bunch of legwork when it comes time to do this install. It is on my list of things to do, just not near the top yet. Thanks!!!
07wingnut
275
124
Clearwater, BC, CA
I did this type of installation on a 4wd Case loader tractor many years ago, with the oil pressure gauge being supplied with a plastic tube. It worked well for a long time, until the day a friend was helping, using this tractor to disk, and not noticing that the plastic tube had broken, and over time the tractor slowly hemmoraged all the engine oil. That little plastic tube resulted in a $3000 engine overhaul. If you must put in a pressure gauge, either use an electronic sender, or a small gauge copper pipe routed in such a way that it won't fatigue due to vibration.
Diydave
L2202 tractor, L185f tractor
Oct 31, 2013
1,635
11
Gambrills, MD USA
True, That tubing does not last forever. If you have it on a vehicle, I suggest a murphy shut-down switch. Had a friend cook off a deutz diesel tractor's engine, that was hooked to a grain drier, when that little tube vibrated against a hot exhaust part...:D:D
7,718
I've spent a lot of money on name brand oil pressure gauges with electric sending units. Last time, after factory sent their third sending unit, I gave up.
I will stick with the mechanical. I install gauges to use them, and I am in the habit of glancing at them frequently. I'll take my chances.
3,091
Having the hot exhaust "close" by - I can see the potential problem of heat cause a serious mess!:D:)
In this case the tube is pointing straight up running through a protective sleeve through the "firewall" and then running into the back of the gauge at 90 degrees.
Like D2Cat said - I look too often at my gauges, and if she springs a leak, left foot will be oil coated!:p
9,118
The tubing can always be sleeved with a piece of fuel line if there is a possibility of chaffing or heat getting it. ;)
Most if not all of the plumbing fittings for the install can be purchased at a good hardware store. The ace hardware here in town sells bstp and npt fittings and adapters from one to the other in brass, black steel, or galvanized. Plus you can get the tubing, and either push lock or compression fittings to hook up the tubing. Just another option besides mail order if your impatient :)
3,091
You calling me impatient?????:D:D:D:)
You been talking to my wife again?:D;):)
I can sometimes put the "I" in impatient!!! - then again as my ol butt moves slower - my mind aint too far behind......slllllooower!!! and a little mo' patient! :)
9,118
Not at all :p I was thinking more along the lines of me!!! Usually something like that occurs on whim, and it's usually a saturday. And I want to get it done right now!!!! Course, I'll burn more in gas, running around looking for parts.
7,718
There's a fine line between patience and procrastination.
I've been told I need more patience. Might be, but I can't be around procrastinators very long........
I've driven 35 miles to Coleman's to pickup a 97 cent O ring!
07wingnut
275
124
Clearwater, BC, CA
I agree with D2cat that the electric sending units do not seem to live up to expectations as far as longevity goes, but when a plastic tube springs a leak, after a couple of years, you're not really monitoring it that closely any more, and these leaks are slow and can occur anywhere along the line. Even if you sleeve this tube, it is still vulnerable to breaking at the ends where the swage lock fittings are. This can really come back to bite you.
procraftmike
Jan 27, 2016
277
10
Neenah, WI
Every system has it's weaknesses. You need to pick one and work with it. It is going to take a little time to drain oil pan out of a 1/8" line. If you are looking at your gauge every minute or 2, chances are you are going to catch it before it runs dry. After all, if that line comes off, your gauge is going to zero. Just secure the line well to keep it from moving around.
3,091
Update on gauges - after installing the oil pressure gauge and it's lighting system, the good ol' light bulb in the temp gauge quit - the incandescent bulb is a filament type and the light is ....well, barely visible!
Here are the lights that I changed too -
http://www.amazon.com/gp/product/B00KLHBUJ2?psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00
now these seem a little expensive ...... 90 cents each!:D:)
ten pack for 9 bucks!
I got to place one in - picture is new LED on right and old bulb on left...
picture is fuzzy as an ape's a$$ - but the brightness shines through!
Changed the other one out too - now my blind butt MIGHT be able to read the gauges.......now that I gots mo better light! The gauge on the right is crystal clear to the viewer.....just not to my cell phone!:D
LRP
202
canada
on aircraft , the fitting on the engine that the oil pressure line hooks up to
is plugged and has a little tiny hole about .060 IIRC. I used to solder the fitting shut and drill a .040 hole.
billrigsby
Mar 17, 2015
1,066
279
Florissant CO USA 8213'
www.facebook.com
In the past I have always used 1/8" copper line and tossed the plastic junk.
