Ultimate Fabricate/Customize Sticky
coachgeo
Nov 16, 2012
2,459
37
Southern OH
Want to have a Get Together with other orange owners... maybe have a regional wrenching weekend to assist each other with modifications, Fabrications or repairs etc... Then join a Regional Group.
See http://www.orangetractortalks.com/forums/showthread.php?t=31393
UPLOAD YOUR PICTURES onto this forum. DO NOT USE A HOSTING SITE and link to them. Here is why....... a wasted opportunity to pass on valuable information.
REMEMBER TO SEARCH. There are LOTs of great links below but certainly NOT a complete list of all the great threads on this board.
What have you made for you tractor
A thread that contains pics with short descriptions and short discussions of items folk have built for their tractor. Got something to add...... please do.
NOTE: If a conversation in that thread on a particular build gets long; a Moderator may separate it out to keep pithy the" What made" thread and to dedicate space to a worthy long discussion.
Helpful Info
. The three different Categories of 3pt attachments http://www.orangetractortalks.com/forums/showpost.php?p=152433&postcount=19
. Calculators for Fabricators http://www.orangetractortalks.com/forums/showpost.php?p=173097&postcount=9
Helpful Fabrication thread links
. Purchasable plans for fabricating Implements
http://www.orangetractortalks.com/forums/showpost.php?p=190309&postcount=1
. De-rusting parts
http://www.orangetractortalks.com/forums/showthread.php?t=23560
. starting at post 10 http://www.orangetractortalks.com/forums/showthread.php?t=23560
. Welding on your tractor
http://www.orangetractortalks.com/forums/showthread.php?t=684
. Collection of links to various plans for building Implements etc.
EDIT: Possibly corrupt link removed by NIW
Fabrications by catagory
Bucket chain hooks
http://www.orangetractortalks.com/forums/showthread.php?t=13166
Cabs- HINT- something can be learned from each thread rather they are based on same tractor you own or not.
..BX1860 http://www.orangetractortalks.com/forums/showthread.php?t=16065&highlight=blade
..BX25D http://www.orangetractortalks.com/forums/showthread.php?t=23229
..L3901 http://www.orangetractortalks.com/forums/showthread.php?t=23272
..BX2370 http://www.orangetractortalks.com/forums/showthread.php?t=20105
..BX2370 Wood build http://www.orangetractortalks.com/forums/showthread.php?t=19008
Fender Handles
http://www.orangetractortalks.com/forums/showthread.php?t=8803
http://www.orangetractortalks.com/forums/showthread.php?t=17663
Front 3pt Hitch
http://www.orangetractortalks.com/forums/showthread.php?t=21698
http://www.orangetractortalks.com/forums/showthread.php?t=14732
http://www.orangetractortalks.com/forums/showthread.php?t=22292
http://www.orangetractortalks.com/forums/showthread.php?t=21675
Front End Loader FEL
http://www.orangetractortalks.com/forums/showthread.php?t=10867 IMHO one of the best threads on the topic by North Idaho Wolfman
Build a (rear, box etc) Blade/Snow Plow
http://www.orangetractortalks.com/forums/showthread.php?t=22394
http://www.orangetractortalks.com/forums/showthread.php?t=18725
http://www.orangetractortalks.com/forums/showthread.php?t=22286 {box Blade}
http://www.orangetractortalks.com/forums/showpost.php?p=173471&postcount=4 {box Blade}
Rear Pallet Forks
http://www.orangetractortalks.com/forums/showpost.php?p=245344&postcount=12
Winch add on
http://www.orangetractortalks.com/forums/showthread.php?t=13864
http://www.orangetractortalks.com/forums/showthread.php?t=9765
http://www.orangetractortalks.com/forums/showthread.php?t=8693
PTO Reverser
http://www.orangetractortalks.com/forums/showthread.php?t=23561
http://www.orangetractortalks.com/forums/showthread.php?t=8269&highlight=Reverser
Engine Upgrades
. Add an Oil Pressure Guage to your Kubota
http://www.orangetractortalks.com/forums/showthread.php?t=23862
coachgeo
Nov 16, 2012
2,459
37
Southern OH
DANG YOUR GOOD!
Not yer first ro-deo I am gessin!
First Tractor Ro-deo.. but not first at riding a Bunking Bronco Bulletin Board. Just here to try to Steer its us-a-bility for users.
Pardonnn... the puns
6,277
Coachgeo, that's a lot of work. Thanks. It should help people get some answers before they have to start a thread to ask, if they'll just use it.
coachgeo
Nov 16, 2012
2,459
37
Southern OH
.....if they'll just use it.
yup. all I can do is try to promote each forum's sticky while somehow not sounding to be nagging to members who are here often
PS.. dont forget to leave links in each forum's sticky that you feel should be added there.
6,277
Coachgeo, put your thinking hat on and figure this out.
Here is a link to a forum I go to when I have a question about a '95 Chev diesel truck.
http://www.dieselplace.com/forum/63...agnostic-checklist-version-2-0-10-2009-a.html
They have a diagnostic checklist they ask new members to fill out before they start asking questions. See the 36 questions?
If folks would stop and fill out a similar form they would stop and learn something about their own tractor before they come online and start asking questions As you know the question are often not with enough information to give them an answer.
Can you modify it to be practical to a wide range of Kubota tractors? Get with that other moderator, what's his name... North Idaho Wolfman, have him help you since he knows 97% of the answers!
3,720
Thats a lot of info listed :eek: but still not the link Im looking for. Thanks much
olthumpa
L275
May 25, 2011
1,501
Maine
Hydraulic calculations
http://www.baumhydraulics.com/pages.php?pageid=4
FREE Online Calculators
Use This Calculator
To Calculate
Sprocket Ratio #1
DIAMETER of Driven Sprocket
Sprocket Ratio #2
SPEED of Driven Sprocket
Sprocket Ratio #3
DIAMETER of Drive Sprocket
Sprocket Ratio #4
SPEED of Drive Sprocket
V-Belt Length Calculator
LENGTH of V-Belt
Hydraulic Calculator #1
PUSH - PULL for a Cylinder
Hydraulic Calculator #2
PUSH - PULL (Cylinder at an angle)
Hydraulic Calculator #3
SPEED for a Cylinder
Rephasing Cylinder Calculator Matching
Cylinders in Series
Gear Pump Calculator
DISPLACEMENT for Gear Pump
Hydraulic Motor Calculator
HORSEPOWER output
Rectangular Reservoir Rectangular
RESERVOIR CAP.
Cylindrical Reservoir Cylindrical
RESERVOIR CAP.
Vehicle Speed
VEHICLE SPEED
dlsmith
BX2230, LA211
Nov 15, 2018
1,254
817
Goshen, IN
This link is dead, takes you to a Google or blank page.
(EDIT) Link removed by NIW
EDIT
MODERATOR WARNING : The link made you go to a site to add an extension to your browser, I don't trust such links ever, and I've got very good computer security!
Doing so could cause you to allow a site to have the ability to steal, alter, or compromise any information on your computer.
To anyone in the future please, if you notice anything trying to do that or anything else odd, send me a PM on it, do not repost the link, as this brings it to the forefront and reels other into the scam.
If anyone has followed the link, check your browser extensions and remove whatever extension it added!
Also do a full security check!
