L4300DT Steering play
Pat54
L4300DT
Oct 25, 2014
Stewart
Hello,
Overlooked excessive pitman wear when I purchased tractor last fall, so now I need some advice on how to remove pitman assembly or if it's possible to remove pitman shaft/bushings without removing the whole assembly?
Just thought I'd ask first before tearing into it.....
pat
bjmsam
L3710 HST
Feb 19, 2010
30
Mount Airy, MD
Re: L3710 Steering play
I have the same issue with slop in ASSY ARM PITMAN 040 on my L3710. Were you successful? Guidance on repairing or replacing TA040-17132 would be much appreciated!
