Little Orange
Kubota BX25D TLB, hitch frame, FEL forks, 3pt steel ballast and back blade
Added a set for skid plates to that very vulnerable under carriage of the BX25D. All that exposed rigging under there made me nervous. The plates when on easy, the hardest part was taking off the little OEM plate, as the bolts are rammed on by machine then painted over and stuck in a finger tight slot.
Note the picture of the rear plate and the new 3” spacing of the tires, see posting on adding the new hubs.
Hope this posting helps other new owners the need to protect your bottom.
