S simon3766 New member Equipment mowing Jan 24, 2015 3 0 0 champion Jan 24, 2015 #1 If you don't replace the HST fan what will happen
S simon3766 New member Equipment mowing Jan 24, 2015 3 0 0 champion Jan 24, 2015 #2 If you don't replace the HST fan what will happen??
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 30,209 6,382 113 Sandpoint, ID Jan 24, 2015 #3 Simple answer: You will overheat the HST unit and cause Thousands of dollars in damage from the lack of a simple part! What model is it? Several are very easy repair, some are a little more complicated!
M mickeyd Active member Lifetime Member Equipment 2014 L3200 DT w/LA524 FEL, 2019 Kubota Z121S w/ 48" Pro Dec, TG1860G w/RCK54TG Mar 21, 2014 1,192 18 38 Guin, AL Jan 24, 2015 #4 Welcome to the forum from Alabama. What happened to the fan?
