Kubota D722 fuel injector pump wont come out.!! Help
Dishtech43
B7300 HST
Aug 21, 2014
Nebo Illinois
Im trying to remove a fuel injector pump off a D722 Kubota engine,The fuel shut off lever on injector pump is frooze up. I took off cover on the throttle and shut off levers in front of injector pump and took off one spring...I think there is suppose to be two springs !, and I took off 4 bolts on injector pump,it comes up about 1/2 inch,and that is all ! I tryed to move lever on fuel shut off,and it dont help..can someone tell me what else too do..I do see two other springs above injector pump not hooked up to anything..thanks
Dishtech43
B7300 HST
Aug 21, 2014
Nebo Illinois
You will need to move the rack back and forth to get the pin to line up with the slot.
Thanks for reply...
But I think the rack. Or the pin is Froze up.. It wont move at all.the injector pump will come up but just to the top of the stud bolt at the top of the pump.The little pin that moves back and forth on the pump is froze up in kill position. Or stop position. Now what.
6,355
Your next best option is to pull the gear case off the front of the motor to het to the rack. ;)
