Pusher plow blade
Tooljunkie
May 13, 2014
4,150
Hello everyone.
I spent a day toying around with the idea of a front blade
Operated with three point hitch.
This is on my l1501 tractor
11 foot i beam, 4-1/2 foot pusher blade
Pivot under axle and welded a bar to connect to 3 point
Lift arms. Two feet behind that are two
24x30 patio blocks.
Theory is up on lift arms- pushes blade to ground
Down- gravity and cement blocks lift the blade.
Suprisingly it works well. Tried to put up photos, but it
I seem to have failed miserably.
gpreuss
Oct 9, 2011
1,166
Spokane, WA
Sounds good to me! Try again with the pictures - while typing a message, drop down to "Manage Attachments" and load them in. The blocks in the back should keep reasonable traction on the rear tires - a great idea! Kudos!You can pill the swivel pin at the front axle and drive away from it, right?
Tooljunkie
May 13, 2014
4,150
Two pins under axle,and two pins on lift
Arms. I have to pull blocks off and back away.
Tried it tonight. A little bit of a pain. Going
To turn blocks 90 degrees so they narrower and
Easier to back over. Pushes that 50" wide blade full
Of gravel.putting my pictures on photobucket,
Easier to post from my phone. My pc is on its last leg and im not
Fixing it.
coachgeo
Nov 16, 2012
2,459
37
Southern OH
found your thread on this.. hmm.... have you figured out how to post pics since you last updated this? If so please throw some pics at us:D
coachgeo
Nov 16, 2012
2,459
37
Southern OH
got word he'll dig it out... hook it up and shoot some pics soon.
Tooljunkie
May 13, 2014
4,150
Havent forgotten. Just that time of year when i get pulled in eleven different directions. Was looking at it. Trying to come up with a need to hook it up and use it. Have a low spot on driveway that needs a touch up.
coachgeo
Nov 16, 2012
2,459
37
Southern OH
Did you mount to the axle with brackets similar to this pic of an OEM set up for a FEL
Tooljunkie
May 13, 2014
4,150
its suspended below rear axle, and carries out back to the 3 point. When i raise/lower bracket needs to move forward and back to go with arc of 3 point. Raise blade-ballast on back will raise blade with gravity.
The more weight the faster the three point goes down, blade raises.
Will try tomorrow, i need to move it before snow comes.
coachgeo
Nov 16, 2012
2,459
37
Southern OH
any luck in getting pics?
Tooljunkie
May 13, 2014
4,150
Blade before mounting,9 foot i beam.
Can drive over it easily.
Im having technical difficulties with pictures, so i am using seperate posts.
Tooljunkie
May 13, 2014
4,150
Not a lot of height when blade lifted, but wanted to keep it short. Cant angle as it will turn tractor or push blade to one side. Will however, lift wheels off ground.
Keep in mind, the i beam is kind of twisty and flexy so when pushing snow it follows the existing grade.
I built it for one time use, to deal with a couple dirt piles in my back yard. It worked very well for what it is. All parts from my junk pile.
Sorry to keep you waiting, colorado low is on its way and i want to be somewhat prepared.didnt need it til now.may work to push cars into shop. Have a cushion to prevent bruising bumpers.
