BX2200 Electrical wiring diagram
Bill hack
Bx2200
Aug 8, 2013
New Bloomfield, Missouri
My 2002 BX2200 is blowing the 20 amp fuse. While mowing the engine stopped running. I restarted and finished mowing. When I pulled into the shed and turned off the ignition the engine continued to run. I found the 20 amp fuse had blown. Upon replacing it the engine stopped. This has happened three times.
I suspect the stop solenoid is the culprit but it is quiet expensive. I am looking for the wiring circuit diagram to see what other component is in the line with this fuses.
Rob Fabry
BX2200 AND komatsu pc150 excavator
Apr 11, 2025
UK
I am at witts end with my fuel solenoid. I have wired new solenoid to battery to rest, works all OK, then plugged into the tractor the start coil works but the hold coil does not, tested hold coil wire and it is getting 13 volts no problems but hold coil still not working, so run a temp supply to the red black cable from battery, still not working. Tested red black cable from ignition to solenoid and it is showing 0 to 1 ohm. Someone mentioned cables below seat was the issue for them so removed seat, found some unused connections (1 x 0v and 1x 12v) but nothing apparent that had pulled out of them. Also purchased new battery and new ignition barrel (both were needed anyways)
Any help greatly appreciated.
audiocontr
bx2230
May 15, 2014
12
Falls Church, vs
Did you ever fix this? Same here.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,960
2,460
WestTn/NoMs
Please start a new thread. Assuming you have a BX2230, the wiring could well be different from Rob's BX2200. The diagram someone posted above is apparently for a BXxx60, which is very likely not like the OP's BX2200.
Start a new thread, stating your facts, and someone can probably help you out.
