Dan_R_42
B7100-D, w/ Sims Cab, B219 FEL, ARPS 70 Backhoe, Oversized R4 Tires, LX2610 Cab
I am having an issue with the B219 Loader Control Valve - detent not holding. With all the snow we have had it has become a major pain - not having the float position.
Has anyone had this issue, where the handle will not stay in the float position? It almost seems like it only happens and does not hold when the temp is below freezing.
I guess I'm just assuming that the valve has hydraulic oil running through the entire valve. Is it possible that there is some moisture trapped in the valve and the detent ball is getting frozen in place. Above freezing I have never had an issue with it. It was working fine last week but the temps were around 45 deg F.
Is there some way to pull the detent ball and spring out without a complete tear down of the control valve?
Any suggestions??? Thanks, Dan
Photo is not my rig, but an identical setup. Hoping the owner of this photo does not mind my borrowing the pic.
