Loader Pins
SidecarFlip
Banned
546
I used to use PB Blaster as my penetrating oil of choice, until I tried a can of Deep Creep by Seafoam. It is more expensive than PB Blaster, but it works much better. Give it a try, and you will never use anything else in the future.
I mix 1/3 ATF with 2/3 acetone in a squirt bottle, beats them all.
russell.still.5
197
Lafayette, Alabama
Well my port a power is only 4 ton so it didn't do much of anything.
Took some oak blocks, a chain, binder and 20 tom jack, and it didn't budget it either.
To get to that one,with the reciprocating saw, I disconnected the curl cylinders and just let the SSQA hang there. It was tight but I was able to get the blade in there.
AllDodge
M9540 RTV1100
Jan 19, 2019
191
South Central, ky
I'm sure I can get it cut, the issue is how to get the piece out after cutting. If I have nothing which can press it out now, after cutting isn't going to make it any better.
Just trying to figure best option before I think of cutting
russell.still.5
197
Lafayette, Alabama
I think I ended up drilling a hole all the way through the pin and used pipe and all thread along with some heat to get it moving. Once it moved it came on out.
3,028
Good adaptation!
