Hello, I bought a GF1800 (which i dont see mentioned much on here for some reason) (D722 engine, 200 hrs) It's an out front rear steer 18HP model, little guy. The last owner had straight water in the cooling system and let it freeze outside. This basically is my first time doing any repair work beyond routine maintenance on anything, so please bear with me.
Problems Caused:
-bulged radiator bottom, lifting it into contact with the engine cooling fan
-cracked thermostat housing
-popped frost plug in gear case (Grey oil)
Q's:
-I had to remove one of the gears to put in the new frost plug. I'm worried that the gears are not sitting the same way they were when i removed it (timing issues?) i see some marks (dots) and I'm wondering how to line these up/calibrate them properly.
-Also, what other problems do you think might have been caused by the freezing? i haven't taken the head off yet, not sure if i should check in there (for frost plugs or whatever).
-Once all is said and done, how do you recommend cleaning out the coolant holding area of the engine? i can see its quite rusty inside.
The tractor was running well enough to load it on the trailer and drive it into my shop when i bought it.
Anything would help, i've included a picture of the current set up (which i believe is close to what it was when i removed the large middle gear)
Thank You.
Problems Caused:
Q's:
Thank You.
