Glad I found this site, I have a L295DT with a loader and backhoe that are both plumbed from the PTO pump. I want to connect the loader to the tractor hydraulics so it can be live. Is there a place to make the connection for the hyd lines or do I have to splice into the existing lines to the rockshaft or 3 pt? Also has anyone had any experience with the 4wd on this tractor? It does not work and sounds like there may be a coupling broken in the shaft feeding the front diff. Thanks for your help. I am sure I will have more questions since this is my first Kubota.
