Fish Lifes B6100 Restoration
3,990
B6100 Low OIL Pressure Fix
Fish - I will post these, but hope we can get back to your project.
You do want the side shelf...good thing. I store 5 ton of wood pellets for a while, so can’t use mine right now. My boxes are also a little messy right now. I have the Weather Channel on my garage ROKU/WiFi fed TV... I compare it to my “Redneck Weather Rope” next to the window . ...[emoji12]
FishLife
177
Destin, Fl
Re: B6100 Low OIL Pressure Fix
Most of the main seals and gaskets i ordered are oem. I was looking at some others on Kumar Bros website. Just curious anyone has any experience with there gaskets and seals?
3,990
I remember some saying Kumar Bros can be sketchy....I think mostly cast parts...don't hold me to it for the baskets, seals, etc......
FishLife
177
Destin, Fl
I thought I read something on here about the cast parts not being so good. I just have not heard anything about the rest of there stuff.
motorhead
2009 B3200, 2007 Dodge/Cummins powered Ram 2500 395hp
May 17, 2012
423
21
Atascadero
When it comes to seals and gaskets, especially ones on the rear main seal, I highly recommend either go to the dealer or make sure the seals are a reputable manufacturer not some China junk.
5,068
Kumar Bros case gaskets are fine, hard to mess those up, but the seals are... lacking, I tried them on a motor and blew the rear main seal out in 10 hours of running, real pain to have to tear it all down again to fix it. :mad:
The head that I got looked good, but the valve job on it leaked so bad the motor wouldn't fire, had to have the head completely reworked. :(
2 of 4 Glow plugs burned out within a couple times of using them, horrible failure rate.
Head gasket blew within 15 hours and overheated the motor again, didn't crack the head the second time, but i chose to scrap the engine and replace it with a newer model!
I still have that stupid expensive head hanging around collecting dust! :mad:
jetattblue
BX1800; L2550
Mar 14, 2018
103
Arlington, TX
Very cool project! Keep up the good work. I am reading along and learning from your thread as I attempt my BX1800 rehab. After a lot of start and stop with parts ordering, I am about to start reassembling the D722 engine.
Very good info about the sealer on the head gasket! I'm going to install mine today or tomorrow. What brand of sealer do you use on it?
4,365
See post #29.
FishLife
177
Destin, Fl
My update from last night. Im a night owl so when everyone goes to bed I use that time to myself to work on things.
Thanks for the title change!
Got the plug tig welded in the end of the cam. That should take care of the low oil pressure.
Check all the measuresments on the cylinders as suggested and all are within specs. Not going to go any further into the block. Disassembled the head completely and checked it over. Checked for flatness and it is within specs. After spending some time looking it over I feel the head is fine and will pass on the pressure check. There is a ton of carbon buildup in the exhaust valve ports. The head looks like it just needs a good cleaning. Valves need cleaning and a little light lapping. The valve seals need to be replaced.
So, What would be the best method for cleaning the carbon out of the ports? I tried carb cleaner but it doesnt seem to do much.
5,068
ABSOLUTELY NONE!
Head gaskets do not get any sealer!
Just make sure all surfaces are clean and install the O ring on the oil feed tube.
motorhead
May 17, 2012
423
21
Atascadero
Check all the measurements on the cylinders as suggested and all are within specs. Not going to go any further into the block. Disassembled the head completely and checked it over. Checked for flatness and it is within specs. After spending some time looking it over I feel the head is fine and will pass on the pressure check. There is a ton of carbon buildup in the exhaust valve ports. The head looks like it just needs a good cleaning. Valves need cleaning and a little light lapping. The valve seals need to be replaced.
Fish, You might look into having the head hot tanked if the carbon build up is bad. Use stainless wire plumbing brushes that are used for cleaning copper pipe before soldering. You have to be very careful to NOT get any scratches on the head or block mating surfaces. Any scratches can cause leakage. You want the surfaces to be Baby Butt smooth. be careful with the pre-chambers as they can pop out. Depending on the head gasket material, whether it has a sealing glaze on it or if it is a dry looking material, the dry type gasket material, the spray copper permatex works real good. The fine copper impregnates the gasket and helps to make a positive seal. There will be some head gaskets where you do NOT use a sealer.
5,068
Kubota head gaskets have Pinto seals (silicone) and using a gasket sealer will make them fail. ;)
motorhead
May 17, 2012
423
21
Atascadero
Good to know. I have seen where guys use gasket sealer when there ids a silicone gasket or seal and all the sealer does is make the silicone slide out of place and fail. Again, it depends on the head gasket or any other gasket material whether you use a sealer or not.
FishLife
177
Destin, Fl
tried cleaning the head with some carb cleaner a little more and didnt have very much success. I dropped the head off at the engine builder that i was going to have pressure check it to be cleaned. should have it back Friday. Kubota dealer called and said my gaskets and seals are in. I will try to pick them up tomorrow afternoon. Going to work cleaning the front axel and frame tonight to get ready for paint.
FishLife
177
Destin, Fl
I picked up my parts from the dealer. I havent gotten the head back back yet from being cleaned. I got the front axel and frame all cleaned. I steam washed the parts first. The axel cleaned nicely. The frame I ended up sandblasting it. I was going to just use some rust oleum paint but none of the stores had any that would match. When I was getting my parts the guy told me that they carry Kubota paint in stock so I got some. Painted the the frame an axel. Probably wont get much done over the next several days with the holidays but I will try.
torch
Jun 10, 2016
2,593
836
Muskoka, Ont.
Please tell me the open engine block wasn't anywhere near the sandblasting operation... :eek:
FishLife
177
Destin, Fl
No. My shop is slit in two rooms. Blaster is in the other. Plus the engine is on a stand now covered with a trash bag. It’s in the background of the painted frame pic. Clean, clean, clean :)
