Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 06-11-2018   #1
John RHR
1st Yr. Apprentice
Equipment: L 245 DT
Default L245LT clutch follow up, more....
Folks -
Thanks to all for your advice on replacing the clutch. Using a torch to cut off the main shaft of the transmission worked wonders! It bolted right up after that! The clutch pedal feels odd, but I think it'll run-in after I get her started.
Seriously, pulled the trans half back out, checked everything, and this time it went together just fine. I screwed up my back, however, so I'm cane'd and hobbled for a few days, but the heavy work is done.
Next question - I am replacing all of the fluids, and am getting conflicting answers as to what lubricant I should use in the transmission/axle assembly. Some say 80 wt gear oil, other say UDT of different weights, so I am not sure. Also, it says the transmission assembly takes something like 34 quarts. It that really so?
If any of you could confirm the type, weight and quantity of transmission lubricant, I'd sure appreciate it.
Again, thanks to all for your advice on getting the clutch issue resolved.
John
John RHR is offline   Reply With Quote
Sponsored Links
Advertisement
Old 06-11-2018   #2
Dave_eng
Journeyman
Equipment: M7040, Nuffield 465
Default Re: L245LT clutch follow up, more....
Transmission holds 23 liters.
Others may tell you the more modern lubricants are better than what was available when the tractor was manufactured.
Certainly very cold weather operation should be considered in your decision.
Dave
Dave_eng is offline   Reply With Quote
Old 06-11-2018   #3
Journeyman
Equipment: L185F
I use universal tractor fluid in my L185.
I did run UDT at first due to dealer recommendations but don’t see need for paying for it for old tractor that does not have any hydraulics except 3PH
Russell King is offline   Reply With Quote
Old 06-12-2018   #4
John RHR
1st Yr. Apprentice
Equipment: L 245 DT
All -
Okay, what came out of the box was not gear oil - it was hydraulic fluid. I see both spec'd, and that OE was gear oil. My feeling is that the two should not be mixed. So if I go with hydraulic, what weight? Can any of you more experience than I offer any specific brands and weights? I am out in the boonies, so will likely be getting the lubricant at wal mart.
All feedback is appreciated, and thanks for your posts so far. Hope to have this running soon!
John
Old 06-12-2018   #5
shootem604
4th Yr. Apprentice
Equipment: L245DT with Kubota (Arps Model 22) FEL and Kubota B/L4520B (Woods 650) BH
The service guy from Kubota told me I could run cheap UDT in my L245DT with no ill effects. Of course they'd prefer if I bought it from them. Some people say the OEM spec oil wasn't suitable for some reason, so Kubota started advising folks to use UDT instead.
shootem604 is offline   Reply With Quote
Old 06-12-2018   #6
John RHR
1st Yr. Apprentice
Equipment: L 245 DT
All - Okay, UDT Hydraulic oil - but what weight should I use. Temps here range from 25 to 112; most of the use of the tractor would be 40 to 100 degree temps...
Old 06-12-2018   #7
VIP Service Tech
North Idaho Wolfman's Avatar
Equipment: L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more
UDT in everything, if your watching costs check out Mystik JT5.
It's an excellent quality fluid at a good price.
__________________
Some days you're being chased by the wolves,
Some days you're running with the pack!
North Idaho Wolfman is offline   Reply With Quote
Old 06-12-2018   #8
Journeyman
Equipment: L185F
To answer your question the UDT is only one viscosity available. UDT is “natural” petroleum product, UDT2 is improved petroleum product and SUDT2 is synthetic.
At Walmart they will NOT have UDT it is a Kubota product and sold through dealers only. You can order it on line.
At Walmart they will sell some type of universal tractor fluid (see Traveler brand at Tractor Supply for example). I believe it will be available in different quality (cost) grades but all the same viscosity grade. (As I understand it anyway)
Old 06-12-2018   #9
John RHR
1st Yr. Apprentice
Equipment: L 245 DT
Okay - I understand that they wouldn't sell a kubota branded product, but would what they sell, generally, work? I won't buy the cheapest grade, but may give the middle grade a go - it's about 50 bucks for 5 gallons, vs 35 for the cheap stuff, or about 70 for the top grade. What do you think?
Old 06-12-2018   #10
coachgeo
Master Tech
coachgeo's Avatar
Equipment: L225 w/woods Few Mowers & Back Blade, D722 in Motorcycle (Triumph Tiger), LMTV
Quote:
Originally Posted by John RHR View Post
... What do you think?
cant get a better suggestion than post #7 from NIWm
__________________
Coach George
Moderator- OTT, AmbulanceRV.com
coachgeo is offline   Reply With Quote
Reply
Tags
clutch, gear oil, l245dt, transmision, udt
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
