Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Implements & Attachments
Implements & Attachments Find everything related to operating, servicing and maintaining that loader, mower, blade, snow blower, tiller, hitch or scraper, right here.
Reply
Thread Tools Display Modes
Old 07-20-2017   #1
gwill
New Member
Equipment: L4150DT
Default Will it fit?
Hello,
I have a L4150DT with the BF900 loader. I have an opportunity to get a quick tach setup from a L4200 with a LA680 loader.
Does anyone know if this is a match? I would like to avoid any fabrication as I will need to travel a bit to get it and alterations would make it less tempting.
Thanks in advance for any help.
Greg
gwill is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-20-2017   #2
workhorse
2nd Yr. Apprentice
Default Re: Will it fit?
If you measure your pin size, and distances from inside to outside of upper and lower brackets, you can easily tell. I can't find any specs on the www
Sent from my XT1650 using Tapatalk
workhorse is online now   Reply With Quote
Reply
Tags
bf900, bucket, l4200, la680, loader
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
