Hi,
(For those who keep seeing my posts, yes I am pretty much redoing everything on this tractor!)
The latest rebuild is the steering box.
My problem is that I have issues on many of the parts with what I would call rust, marring, pitting.
There are 52 ball bearings (I thought there were supposed to be 54), and the majority (see attached picture) no longer have a chrome/smooth surface. In fact, they look black.
Also the steering nut has pitting inside, and the steering shaft does as well on the top bearing surface.
The simplest thing to do is get a new nut/shaft combo (I already have the rebuild kit for the box), but I was wondering if there are any stop gap measures that I could implement instead of a replacement.
The steering seemed fine before (even though it was mostly water in the box!), and I was wondering if I am in a place where it will last quite a while longer if I just assemble and lubricate.
Also....any ideas on polishing the upper bearing surface on the shaft?
Thanks,
Jim
Thanks,
Jim
