Work Shop Manuals (WSM)
td0g
Z482-E3
Jul 28, 2015
Sydney
Hi everyone, I have been trying to locate a WSM for the Z482-E3 engine but have been told by two different dealers that one does not exist. I have seen the link to the servicing specifications, is that all there is for this engine?
5,118
td0g
Z482-E3
Jul 28, 2015
Sydney
Is there a trick to using the parts list site? I input the model number Z482 and I get nothing, I tried my 6 digit serial number and it says to only enter 5 digits, knock a digit off either end and it comes up with nothing. Maybe this engine is not sold in the US?
coachgeo
Nov 16, 2012
2,460
32
Southern OH
Parts list site is a "tractor" parts list.
To get part numbers for a z482 you would have to search by a Kubota model of tractor that uses the Z482 engine.
Grouse Feathers
Feb 16, 2015
1,022
Lovells, Mi
The WSM for my BX2370 is $94.34 plus shipping from Messicks. The WSM for BXxx60s is free from Kubotabooks.com:
http://kubotabooks.com/AutoIndex/in...df&AutoIndex=5d2be80d3894fd4209a81b87e79dbfe0
I have been using the WSM for BXxx60s and so far have only found minor differences. If I ever have a major repair the cost of the WSM for a BX2370 would become minor, but for now the WSM for BXxx60s is a valuable resource.
5,118
td0g
Z482-E3
Jul 28, 2015
Sydney
Thanks everyone for the tips on the Z482, I found the part numbers I need to get.
Aluthin
Kubota B6000
Aug 7, 2015
United Kingdom
Hi all just got myself a kubota b6000 and it came with a s850.... i have managed to get the service manual and parts manual as pdf's for the b6000 but haven't managed to find a wsm for the s850. Also anyone have a high quality wiring diagram for the b6000 as the one in the wsm off kubotabooks isn't clear enough on the switch positions.
5,118
The wiring diagram doesn't show switch positions.
Correction on that diagram it does have a note of it, and yes not very clear.
Aluthin
Kubota B6000
Aug 7, 2015
United Kingdom
Thanks wolfman i'll just photograph before I disassemble and draw up a new diagram as I go..
Do you know what bulb to use for the glowplug light as it hasn't one in.... plus if I want to replace the horn am I right in thinking any 12v motorbike horn would do the job.
Thanks
5,118
The glow plug Indicator is not a bulb or light, it's an open air heating coil, that will glow red when it reaches temp. ;)
William1
BX25D
Jul 28, 2015
1,085
269
Richmond, Virginia
New owner of a BX25D
While I know you can view and print individual pages of the parts book, is there a source where I can simply d/l the entire thing? I got one for the BX24D and it appears to be near identical.
Aluthin
Kubota B6000
Aug 7, 2015
United Kingdom
Try kubotabooks.com see if there is one there
Southernfarm
2014 BX25D
Jun 8, 2016
109
Southern MB
Re: getting part manual pages and part #'s from kubota.com
USA Parts break down with drawings and part numbers. For those outside the US you can attempt to connect to these thru a proxy that will emulate another country than where you're really connecting from. NOTE: Part numbers in your country may not match exactly with those from USA. More info: http://www.howtogeek.com/210614/how-to-access-region-restricted-websites-from-anywhere-on-earth/
. Go here http://www.kubota.com/part/parts.aspx
. Hit the [Illustrated Parts list] button
. accept the legal thingamabob
. Hit [OPEN]
. type in [Your tractor such as L2250 ]
. Select your model [DT or not, HST or not etc]
. Open the various sections to search out which one will show your the parts break down and part numbers for blades etc.
Work Shop Manuals can be purchased at:
http://www.colemanequip.com/,
http://www.messicks.com
ebay, Amazon etc.
Above illustrated parts only available to US customers. Here is the link to the Canadian English version.
http://kubota.ca/en/partsdisclaimer.aspx
Rolling Stock
L4350DT, LA950 loader
Jun 17, 2016
25
Othello, WA
Hello all,
New maintainer of a used L4350DT with a LA950 FEL. I cannot find a manual for the LA950, I only see it for the LA950A. Are there many differences between the two? I specifically need information on how to remove the FEL. I know there are 4 bars to be used, I have the 2 mounted across the drivers station and am missing the 2 that get mounted to the lower rear frame rail. After I receive these 2 lower bars how do I attach them to remover the FEL? A picture would suffice, a manual would be preferred, any help is appreciated.
