Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 08-22-2014   #11
VIP Service Tech
85Hokie's Avatar
Equipment: BX-25D Filled Rears,Bro Tek Spacers,Piranha Tooth Bar-90'&'92 B7100HST
Default Re: Bxpanded hydraulic pressure test and adjust kit
Quote:
Originally Posted by Wrencher2423 View Post
Just ordered kit . Where is thus spring you talk of?
Back near the 3 point, bolt pops out , spring comes out, washer in , spring back in, tighten snug - torque. and bullya
__________________
"Teaching is the one profession that creates all other professions"
85Hokie is offline   Reply With Quote
Sponsored Links
Advertisement
Old 08-22-2014   #12
koja
3rd Yr. Apprentice
koja's Avatar
Equipment: BX25D
Thumbs up Re: Bxpanded hydraulic pressure test and adjust kit
Good thread ! Thanks for the info. Ordering mine tomorrow. I'm looking for 1900-2000 , lines are rated at 2200 all day. Think I'll be good. This doesn't effect the transmission ??? thinking they are separate.
koja is offline   Reply With Quote
Old 08-23-2014   #13
Gundoctor
2nd Yr. Apprentice
Equipment: Kubota M7040 4x4/ BX2230 4x4/ JD MX 8/ Ford 101 Moldboard 3 bottom Plows -
It has a photo with the kit where to put shims.
Gundoctor is offline   Reply With Quote
Old 08-23-2014   #14
VIP Service Tech
skeets's Avatar
Equipment: BX 2360
Thanks 85, as I get older one thing I have learned,, if it aint broke don't fix it,,lol
skeets is offline   Reply With Quote
Old 08-23-2014   #15
redfernclan
2nd Yr. Apprentice
It was mentioned that you can get the adjustment shims at McMaster Carr. I searched and couldn't find the specific listing, does anyone have the part number? I don't think I'm THAT cheap that I couldn't buy the kit, but I was a heavy equipment mechanic for about ten years and still have all my tools, gauges, hoses ect. for testing and I don't really see a need to buy more. I am not a fan of cranking the pressure to the sky to get more work done, I have seen it too many times in the past. I have read enough on these little tractors [BX] to also know that the manufacturers lean toward the lower side. Saves on equipment and if it's not needed, no sense being so hard on things. But, there is no harm in making sure it is where it is suppose to be and as long as you keep it reasonable, tweeking it up a bit. I'm talking a couple of hundred psi, not up to say 2,500.
redfernclan is offline   Reply With Quote
Old 08-24-2014   #16
VIP Service Tech
85Hokie's Avatar
Quote:
I couldnt stand it anymore.....I too went ahead and ordered MINE!
like a kid at christmas! Now the hurry up and wait!
__________________
Old 08-27-2014   #17
lamanated
1st Yr. Apprentice
Equipment: BX
a friend borrowed the gauge off the shop press hooked to the hydraulic coupling off a line. and ordered a few shims. took 10 min to do the job for under $3
lamanated is offline   Reply With Quote
Old 08-27-2014   #18
davebarnhart71
New Member
Equipment: 2014 bx25d loader backhoe 60" mower
I guess I could have cut some shims from stock and used any hyd gauge, but I wanted to be safe and just buy the kit from someone who has done their research, and included their knowledge with it, I would like to go to 2000# but this is a brand new machine under warranty, I don't want to be responsible for any failures.
davebarnhart71 is offline   Reply With Quote
Old 08-28-2014   #19
ThisIsNotaStep
2nd Yr. Apprentice
Equipment: 2005 bx23 tlb
Any one have pic or diag of the location of that "bolt near the 3pt"? I have a 2005 BX23 I'd like to check & adjust if required.
ThisIsNotaStep is offline   Reply With Quote
Old 08-28-2014   #20
Underwhere
1st Yr. Apprentice
Quote:
Where are you ordering shims from and you have part #'s or sizes?
Underwhere is offline   Reply With Quote
Reply
Tags
backhoe, bx25d, bxpanded, digging, hydraulic
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
