Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 04-06-2014   #11
VIP Service Tech
North Idaho Wolfman's Avatar
Equipment: L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more
Default Re: Servicing a B7100 w/ B219 Front End Loader
Yes I would use a Dremel and cut off wheels to cut it off.
All you really need to do is cut the ends off one link and drive that link out.
North Idaho Wolfman is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-06-2014   #12
Dan_R_42
3rd Yr. Apprentice
Equipment: B7100D, w/ Sims Cab, B219 FEL, ARPS 70 Backhoe
You need to be looking at both sides of both chains. You will only find the master link on one side of each chain. All the rest of the links will look the same.
Any chance you can get photos of both sides of your chains. Wow, I don't see how the chains could have been put on without using a master link.
Look for the little retainer clip to find the master link
Click image for larger version
Dan_R_42 is offline   Reply With Quote
Old 04-20-2014   #13
Big Kahuna
3rd Yr. Apprentice
Equipment: Kubota 2000 L3010 HST with Loader ,1992 B7100HST , B6100E
Talking Re: Servicing a B7100 w/ B219 Front End Loader
Just take the pump off as a unit, it slides off the front crank shaft, its a hella lot better this way, those double roller chains isn't cheap, and as for the rebuild of the Cessna control valve, Eaton sucks for support or parts, I tore down and bought seals to repair, I had to buy them 100 at a time, but I have the seals.
Big Kahuna
Big Kahuna is offline   Reply With Quote
Old 04-22-2014   #14
seanbarr
3rd Yr. Apprentice
seanbarr's Avatar
Equipment: B7100DT (sold) - Branson 3520H
Default
Same here, slide the pump off. I was able to work on the radiator, alternator upgrade, and wiring with the front loader on the ground.
seanbarr is offline   Reply With Quote
Old 04-22-2014   #15
etmccaus
1st Yr. Apprentice
Equipment: B7100DT
Quote:
Big Kahuna
Talk about timing...you posted a day after I cut those chains off. No master links on either one. Oh well. I shall rebuild or replace 'em. But lesson learned about sliding the pump off.
Spent the evening trying to hunt down that seal kit. No kidding about lack of service/ support information. Think I found a place that sells 'em but at $8 each and a minimum order of $50...sigh.
__________________
Evan M
'79 B7100/ B219 FEL
http://thekubotaproject.tumblr.com
etmccaus is offline   Reply With Quote
Old 04-26-2014   #16
Dan_R_42
3rd Yr. Apprentice
I'm curious with no master links how was the chain put on in the first place?
The master links are about $3 each, not available from Kubota dealer. Got them from a bearing supply company.
The replacement chain with the master link was about $25 from Kubota this past March.
Reply
Tags
b219, b7100, fel, front end loader, removal
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
