Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 09-28-2017   #11
jasowiii
1st Yr. Apprentice
jasowiii's Avatar
Equipment: Kubota L35
Default Re: M4000 pump and FEL
Next problem, the Greson valve no worky!
My guess is that the fluid is just flowing through the valve and not resulting in pressure to the cylinders. It had a gizmo on the outlet (I'll call it a regulator) that we removed cuz it was damaged. My assumption is that this device creates a differential pressure rather than dumping the fluid back to the resivour.
This regulator seams hoky.
Any advise on the correct way to plumb this thing?
Click image for larger version
ID:	31763   Click image for larger version
jasowiii is offline   Reply With Quote
Sponsored Links
Advertisement
Old 09-28-2017   #12
007kubotaguy
3rd Yr. Apprentice
007kubotaguy's Avatar
Equipment: B7100DT L245DT JD 2355
Hello
The hose closest to the Tractor should be the pressure in to the valve. The outside hose would be return. Are you sure you have pressure to the valve. You could make a simple gauge set up to check pressure at the remote couplers. Just use a Male pioneer tip and put a 3000 PSI gauge on it. Plug it in to the Cupler and read your pressure. You may also want to get rid of the galvanized fittings. They don't do well under pressure. Good luck Lance
007kubotaguy is offline   Reply With Quote
Reply
Tags
fel, hydraulic, loader, m4000, pump
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
