L2501 vertical exhaust mod
billrigsby
Mar 17, 2015
994
134
Florissant CO USA 8213'
www.facebook.com
I like the idea, my old L1500 came with the upright exhaust and
I always wondered about how the bottom exhaust systems worked
out seeing the exhaust coming out of mine.
Are you concerned with engine vibration and a solid mount
to the tractor?
:confused:
greenacresnorth
L2501,BH77
Feb 18, 2018
175
Morganton,NC
dont think it will be a problem, there is a bit of flex in the elbow and horizontal part, plus motor is solid mounted, loader frame is bolted to engine block, there for they kinda all move together.
hope to float
L3450
Feb 18, 2018
467
60
Ireland
Nice bit of work. Just be sure that the stack is taller than your head when you are in the seat. You don't want to be working downwind of it on a heavy day. Ask me how I know....
greenacresnorth
L2501,BH77
Feb 18, 2018
175
Morganton,NC
its a few inches below the ROPS and well over head, went with the smaller pipe to keep velocity up and blow it away, ran it all day Sunday and never once smelled exhaust running loader and backhoe.:cool:
Stomper
2017 L2501. Landpride Mower. Farm King Snow Blower. DIY Root Bucket grapple.
Jun 30, 2017
240
Northern Canada
Great job. I have 87 hours on my L2501 and HATE the black on the loader arms also.
cliffboyer
L3301 w/LA525 loader, G5200 mower w/RC48 deck, Kawasaki 610 Mule, DR mower
Nov 30, 2017
240
Southern IL
That is a cool mod.
My Iseki has a vertical stack, and rarely has the exhaust been a nuisance.
Wonder if doing this mod on an L3301 w/ DPF would cause any issues during REGEN. Using larger pipe might be in order.
4,853
That is a cool mod.
Yea, you having an emissions based model I would advise you to avoid this mod like the plague! ;)
4,853
That is a cool mod.
Yea, seeing that you have an emissions based model, my advice would be to avoid this kind of mod like the plague! ;)
sheepfarmer
Nov 14, 2014
4,440
654
MidMichigan
That is a cool mod.
The op's reason was to avoid the exhaust stains on nearby parts, but the tractors with dpf don't do that, so no point in moving the exhaust. And then there is the reason that NIW mentioned. The exhaust is REALLY hot during a regen. Bad idea to mess with any part of that system..
cliffboyer
Nov 30, 2017
240
Southern IL
Agreed....was just wondering out loud.
Sage advice I will heed!
With only 12hrs or so on my L3301, I have yet to witness a REGEN cycle.
lescarpentier
B3350
Oct 12, 2016
73
Washington
For the most part this is true,but north of 300 hours the loader on my B3350 is definitely stained by the exhaust.It could be from the heat of the regens or from the raw diesel fuel that you can smell sometimes during the regens but it is stained.The paint on the shield at the end of the exhaust pipe has been cooked off for a long time now.As sensitive as these DPF systems are I wouldn't consider any kind of modification whatsoever either.
thebicman
B2601 + BX2755HD + 50" box blade
Feb 2, 2017
328
89
Ottawa, ontario
When I got my used 8hrs B2601 the exhaust was one of the first things I modified. Copied someone else's idea on the forum and added a small turndown pipe. Keeps exhaust off the front attachments and less then $5.00.
sheepfarmer
Nov 14, 2014
4,440
654
MidMichigan
Good point Les, I shouldn't extrapolate from an n of 1! My 3560 has an entirely different regen system and engine type from the 3350s, There is a big difference in the exhaust of the l3560 (dpf) and the B2650 (no dpf). The 2650 has exhaust marks on the front axle 100 hrs, and the 3560 does not at 300 hrs. Assumed it was generally true, but the B3350 has a way more complicated and frequent regen. In any case not a good idea to mess with routing.
greenacresnorth
L2501,BH77
Feb 18, 2018
175
Morganton,NC
you will still get ash stains, not black like diesel soot but a white grey ash that takes up moisture and turns grey brown over time. next time your on the interstate look for a newer semi truck, look inside the stack outlet and around the sides where the moisture runs down, thats kinda the same thing your seeing on your loader. I went to a new Manitowoc MLC-300 last week that has DPF and DOC/DEF, the whole back corner where the exhaust comes out next to the counterweight track frame was covered in a grey white ash film, looked horrible!!!! I will try and get a picture of it next time I see it again.
dcarter
'94 B7100-HSD-D
Apr 6, 2012
Cypress, TX
Funny, everyone has different views I guess. When I moved up from a B7100 to a L2501 a month or so ago, I was thrilled with the exhaust location and haven't noticed any black areas on the loader. I would be worried about tree branches hitting the vertical pipe, but nice fabrication.
greenacresnorth
L2501,BH77
Feb 18, 2018
175
Morganton,NC
for me personally its no big deal, im used to running equipment with mirrors, stacks, glass and other crap to get torn off, I am good about clearing all my trails and limbing trees up to clear with no issues.
Stomper
Jun 30, 2017
240
Northern Canada
You will. I have 100 hours on my L2501 and also hate the mess it makes.
Kjadams811
L2501
May 8, 2019
16 hours on tractor and already sick of the black stain on loader and front tie rod, a little 1 3/4" pipe and some welding and this is what i came up with.
I am planning on doing this nearly exact mod in a few weeks. Have you had any issues with the exhaust getting to hot next to that plastic near the dash. Didn’t know if I should position the vertical exhaust a few inches more foreword.
