Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 12-04-2018   #1
FishLife
2nd Yr. Apprentice
FishLife's Avatar
Default Fish Lifes B6100 Restoration
*This thread is about the complete restoration of my B6100*
So, I have to address the low oil pressure issue. Already took the oil pressure sending unit out and used a gauge and confirmed I do indeed have low oil pressure. I suspect the the plug in the cam fell out as other have experienced.
During my test thought I noticed the gauge only read 3-4 psi higher at half throttle vs idle. I still plan to go in and check the plug but what are the thoughts on the oil pump and the relief valve?
FishLife is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-04-2018   #2
VIP Service Tech
North Idaho Wolfman's Avatar
Equipment: L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more
Default Re: B6100 Low OIL Pressure Fix
Quote:
Most likely neither the oil pump or the relief valve will be the reason for the low oil pressure, both of those are just about bullet proof, but for grins you can easily pull the relief valve out when you drop the frame before you take the gear case cover off.
__________________
Some days you're being chased by the wolves,
Some days you're running with the pack!
North Idaho Wolfman is offline   Reply With Quote
Old 12-04-2018   #3
FishLife
2nd Yr. Apprentice
FishLife's Avatar
Quote:
Just wanted to check. I'm looking at the parts diagram trying to put a list together of the parts needed for the repair. does this symbol (<=) mean before a certain serial number and this (>=) would be after?
Old 12-04-2018   #4
FishLife
2nd Yr. Apprentice
FishLife's Avatar
Also is there a post that someone has done a step by step to shoe the process or a video? I tried a search but unless its buried deep in a thread I couldn't find one.
Old 12-04-2018   #5
VIP Service Tech
Yes it does.
__________________
Old 12-05-2018   #6
FishLife
2nd Yr. Apprentice
FishLife's Avatar
This may be a stupid question but I have know idea and I dont see a reference in the WSM. Is it necessary to drain the oil before removing the gear case cover?
Old 12-05-2018   #7
VIP Service Tech
Yes as the oil level will be above the bottom of the gear case.
__________________
Old 12-05-2018   #8
FishLife
2nd Yr. Apprentice
FishLife's Avatar
Thanks. I also have to replace the rear main so I know it would have to for that. Since I already have the axle off, I will just pull the engine and put it in a stand.
Old 12-05-2018   #9
VIP Service Tech
Note that there are two different gaskets on the rear main bearing holder, order you'll need both.
__________________
Old 12-05-2018   #10
FishLife
2nd Yr. Apprentice
FishLife's Avatar
Thank you, I just got the motor pulled. Probably going to have to add a clutch to the list. This one has been running in an oil bath.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
