Go Back   OrangeTractorTalks - Everything Kubota > Kubota Talk > Service, Repair & Maintenance
Service, Repair & Maintenance Offer your Kubota service advice, repair procedures or maintenance tips. Have a service related question? Post here.
Reply
Thread Tools Display Modes
Old 04-15-2019   #1
simpson1
1st Yr. Apprentice
Equipment: l4240 and b1700
Default HELP- Kutbota B1700 Bi-Speed front axle removal
I'm trying to remove the front axle on my b1700 to fix the leaking pivot seal but the axle won't seperate from the bi-speed turn box. Does the bi-speed come off the tractor or can I leave it on?
Click image for larger version
simpson1 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-17-2019   #2
RTMach1
New Member
Equipment: B2400 HSD-Bi speed, 60" MMM, B2019 front hyd blade
Default Re: HELP- Kutbota B1700 Bi-Speed front axle removal
The bi-speed box stays with the axle, just disconnect the actuating cable from the arm. You can remove the bi-speed gearbox from the axle after it is off the tractor.
RTMach1 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
